Ok, im curious of opinions here---im getting that 360 magnum motor this weekend, been thinking about the front of it. Should i put on all the premagnum stuff and make it so i can use the mechanical fuel pump, or should i leave the serp belt setup on it and run an electric pump? I kinda like the idea of the serp setup, but im not sure how much of a pain its going to be to make things fit or convert them.
