Took me almost all day to build the fuel pump mount, make the lines up, and bolt the carb on. If that gives you any idea how much i slowed down due to the heat outside.
Of couse it took me almost 2 hours to get the clamp for the feed line off the sending unit because some ding dong put the adjuster screw on the very bottom with everything in the way. I think the bed was off at one point because i couldnt get to any of the clamps easily
