Quote: ... Most people who dont like it just did not run it in the right combo. Ron
EXACTLY
what's the right way??? I'll tell you, 3000 stall, nice headers, high compression, decent heads and 3.91's or better. So he has a stcok stall and 3.55's is it going to run well?
yup
I think you need to get off the
Tell you what you put together a stockish 440 w/ mani's, stock stall, 484 cam and 3.55's I'll do the same with and use a el-cheapo special from Summit or Jegs and spot you a light or two.
why? you just a sucker for punishment? or is that just howz yah like it.
