Quote: Which 284 484 cam... There is original 0235 and the later one 07697. The later one is much more streetable with less overlap. We have run the 0235 in a couple of different engines with good sucess, its downside is low vacuum so if one has power brakes... Check it out..
I have ONLY ran the P4120235 cam, never tried the newer one... Power brakes with small reservoirs in most of the vehicles. No hard pedal, ever. K car boosters.... 68 A body boosters, you name it.
This was my wife's daily driver, it's booster is straight out of a K car.
