Speaking of the Mopar Performance Cams, has anyone ever profiled the lobes for comparison.
I would like to see the actual duration numbers measured at least at these tappet lift points:
0.006", 0.020", 0.050", 0.100", 0.200".
Does the 284/0.484" cam actually measure 241 duration @ 0.050" like the catalog claims?
Also, Mopar lists the appliaction for the 284/0.484", 108 LSA as "Drag Mod. Comp", and even designed a 114 LSA version of the cam with the application notes "Revised centerline for improved drivability."
OK, I give up. If you insist the the 284/0.484 108 LSA cam is the best cam, Then I'm wrong, along with Mopar for re-designing their cam, and the other cam manufacutrers are wrong for creating the Hughes Engines cams, or the Laniti(sp) Voodo cams, or the Comp X-tream cams or the Crower Compu-pro cams.
