Quote: I'm sure I could do better with another cam like you said, but I will need a converter for another cam too.
I was hoping not to crack the motor open at all. It's easier for me to change out the torque conveter, it only takes me an hour or 90 minutes.
Sounds like I need to change out the converter first, if that doesn't light a fire under the car then I will consider a new cam. I'm convinced this car is build to run a lot quicker/faster than it is. My small block Demon will blow it's doors off right now.
LOL I'd rather do 3 cams then pull one trans. The 484 + moni's + stock convert + 3.55's = slow. Just get a good cam and leave the converter alone. You'll still need 3.91's even w/ a converter not to mention a good converter is $300+ and a set of 3.91's is anoher $190 just for ring/Pinion.
