Can anyone say if they changed the coil pack for the Demon? I know the 6.2 Hellcat uses the same coil as the 6.1 and 6.4. IF the blower is pushing 35psi I would think they needed to upgrade the coil. Hemiup found this out will pushing 28 PSI through a 6.1. IIRC Matt
