These doors have good hinges, and the door pins are new. The doors open and close well, but after you close the door, the body line on the door doesn't match up with the same body line on the cab. The passenger side is off nearly 1/4"! Remember, this was the side that was badly damaged. I'm wondering what I missed. I can open the door and lift it up to line up, but can't feel anything loose or move. One day my son stopped by, and I had him lift on the door while I watched for movement. What I saw was the hinge was moving on the door frame and the hinge was moving on the door post!
Pic 1, See how far off the two body lines are?
Pic 2, The hinge was moving on the door frame. This weld helped a bunch.
Pic 3, The door skin was separating from the door frame. These tack welds solved the problem.
Pic 4, Not perfect, but much better. And yes, the striker post on the door jam had this much adjustment.
