-Outside door handle cont.
Pic 1, Once the location is determined, mark the hole out on the door and cut it out. I like to use a cut off wheel.
Pic 2, I usually make the 1st cut a little small.
Pic 3, Then its fine tuned. Its easier for me to sneak up on he hole size.
Pic 4, With the hole cut to size, I make sure the latch rods are close, if OK, then I weld it up. Then its a matter of connecting the rods.
So I got the handle in the truck and it worked great, until I installed the door glass. When the door glass is up, the outside lock lever makes contact with the glass before it can lift enough to lock the door. If the window is down, it works great. I pulled the lock out for now. I've purchased a remote lock that I will probably install in the spring. About that best laid plans thing... At least the doors open and close great. Gene
