Door latch cont.
Pic 1, The inside sheet metal patch. The area inside of the black marker will be cut out. Viewed from the door edge.
Pic 2, Same piece, different angle, again, the area inside of the black marker will be cut out. Viewed from inside of the door.
Pic 3, The cut out has been done, the mounting holes for the latch have been drilled and the latch has been screwed into place. I'm hoping the screws will hold the latch in place well enough. If it does, If I ever have to change the latch, I can do so without removing the glass. This is viewed from the door edge.
Pic 4, As viewed from inside of the door. That lever with the light green clip is for the inside door lock. A rod will connect to it to unlock the door from inside of the truck.
