The white paint on the doors, rear panels and A-pillar/windshield trim was sprayed yesterday. The metal upper corner pieces on the windshield needed a little filler work after some big dents were straightened out. When the factory welded the A-pillars to the upper windshield support, they left the welds big and messy. When the corner pieces were installed, they touched the welds and were dented as they were being screwed down. I ground off those excess welds so that shouldn't happen again.
