FYI My car is almost together Dyno testing within a month The fuel system fast xfi aeromotive eliminator pump aeromotive fuel pump controller to save the pump on the street fast 90 mm throttle body 83 lb injectors
This would be good to about 1000 hp and you can step up to bigger injectors or 2 sets of injectors for more HP
