No progress on the A-100 that started this all, but have been busy with the 8 door roof and working to get the 108 running again.
I recovered the doghouse, replaced the freeze plugs, water pump and thermostat housing. Got the WP pulley, spacer, fan, air cleaner and breather all blasted and will paint.
Also ran new wire for the engine sub-harness, just need to add terminals and a resistor for the coolant wire, then connect to the connector.
EDIT: got more done, here's how it looks now.
Still need to loop the heater hose, get a shorter bolt for the intake, mount the choke and return spring/bracket, finish the fuel line and complete the wiring harness. Oh, and replace the noisy alt bearing.
