Cleared out space, hope to hear from you.
Got a quote today for soda blasting the van.
Still trying to decide if I want to do the grunt work or have it done. Most people say that after doing one, they will pay to have it done. The quote was for 1800 inside and out, not underneath.
I did pick the color for the van outside. I always planned on White inside, and another outside. After seeing that the new Plum Crazy is darker than the older color, I'm going with the new one. The paint is reasonable from the store, so it's going on!
Got a couple things at MATS for the van, so it's mostly work at this point. Will still need a few items and a complete set of weatherstripping.
Also got the front axle out of the truck, the only things left are the brake lines and P.valve and hacking out the dash shifter area.
Next strip out some more on the van and restore what's off! Still avoiding metal work for now. I want to drop the front another inch or two if everything will clear.
