I know he lives here, and the past owner of the house described about where he is, but I'm not sure exactly where. If you can PM a location, that would be great.
I have heard thru the grapevine that after his HUG retirement at MATS, he decided to whip up an A-100.
Gene Adams (early hemi drag engines) lives out here too.
Saveable?
That will depend on the mechanicals. Hoping to at least see if it runs, moves and stops before making that decision. The roof has leaks and rot. The inside looks like it should clean up. The exterior is okay, haven't really looked at the underside. If it can be done on a budget, I will try after some of the others get finished.
