I have heard a lot of folks complain about Indy parts and service and I have to wonder why
. They are the ones that made it possible to build a 800+ HP wedge. It is mandontory however to machine and fit the parts corectly. There is no way anyone should expect to just bolt a motor of that horsepower with off the shelf parts.. Indy pushrods were designed to work with many different combos with one standard "cut to fit" kit that comes in there top end motor package. Do you realize how many different lengths they would need to stock to fill everyones needs?? I am sure that if you bought a complete motor from them over 528cu.in. it would not have cut to fit Indy pushrods in it. It sounds like you may have other issues causing the pushrods to break...
Indy products make Mopar racers much more competive..
