Quote: to get the lines thru the firewall, use the oval plug just below and left of the steering column, it is the hole that the clutch pushrod would go thru if it was a four gear. you can use any of the bigger holes on the water pump housing,. you will have to use the adapters in the kit. the iol line will hook up to the back of the block. look back there and you will see the electric sending unit, the is another plug on the back, at opposite angle from the sending unit. again, use the adapters. you can pm me with anyquestions. beeps
plug opposite from sending until remove use that hole
