The condenser isn't blocked up.The picture makes it look bad but it's not. There is a good deal of room between the radiator and the condenser and there is space between the cooler and condenser. There is also plenty of air flow through the grille and under the bumper. He also has a air dam that is directing air up into the front. Air to the radiator isn't his problem. The radiator has a shroud that covers at bunch of the back side and leaves air through the fan area only. As I said earlier the fan housing has very close ribbing that cuts down a bunch on air flow.. That is a big restriction. AHall please post a better picture of the engine side of the radiator and fan for clarification. One more directly at it instead of from the side.
