Quote: If the problem was at low speed I could see the a/c condenser and trans cooler being the problem but his trouble is at highway speeds which should rule that out.
That's an air flow issue thru the rad .Here's a test , pull that fan setup out of the car and go for a ride ...
I don't think that will help any... He might as well put cardboard over the grille
