I had same problem.Have a 69 gtx with air .Seems like your fan is not pulling enough air .How many amps is it pulling and looks like you have a stock altenator.Ended up getting a hhr fan solved the problem.After market fans don't pull as much air as a factory fan.Do a search on here for electric fans.
