How big a radiator, 22 or 27? I got the hoses figured out for a 27", the radiator a friend gave me is a 27", only needed one patch and a cleaning ($35!), the remote filter and the radiator hose down there get kinda cozy.
On you rear brakes, how big is the front? If you have 11" disks then using the 11" rear drums you'll have to bias down the rear quite a bit, if you have 12" disks the 11" will be fine. On my Cuda I use 12" disk front and a www.tsmmfg.com 11" disk rear kit, well balanced and I didn't need to dial down the rear any.
