I’ve hit a quandary on the hemivert and would like some opinons. In hanging the braided fuel line (-8 and -6) from the front to the rear I really don’t like the droopy factor I’m seeing. I could cut holes in the SFC Clair and I hung and run the lines thru the SFC but that would preclude inspections on the lines. Another solution would be to use that handy -AN flare tool Clair’s got and run hardlines front to rear and connect the braided hose at each end to its respective place (fuel rail, regulator, pump/cooler, and tank return). If I do this then what size hardlines are appropriate, ½ and 3/8 ths?
