Quote: MP wanted to make it easy as possible for guys with older cars to install the crate motor, so they stripped the PCM down to the bare essentials to make it run in that application, and made it 100% simpler than the production wiring/computer. Open loop/no 02 sensors at all. Pretty much all your sensor readings are on the intake side + temperature related stuff. Must use a hydraulic shifted trans, also.
well after you put it that way it now is starting to make some sence. thankyou zippy for explaining this.
