And more powerful too!!! For even more power (and disable the 5700rpm hard limit) Ben Grasso at www.pfcenterprises.com has an ecm and a feedback system that uses wide loop O2 sensors for true control on the efi. As it is stock the crate motor has no O2 sensor feedback.
I got some stuff done so far, I found a 727 inspection plate but had to cut it square to fit around the motor, everything is buttoned up now. The plate and starter have to be in place before the headers swing into place. Last week I slept the entire weekend, didn't get a thing done on the vert...
