I don't know, I'd like to use my stock cable (slant 6) since it'll be long enough, otherwise I may have to go Lokar, OR if I use the late 80's/early 90's Dodge truck I'll need to use it's cable since its a different design as far as mounting to the bracket. Kickdown will more than likely be cable operated (Same Dodge truck or Lokar again).
