I picked up the oil filter rig from Canton Racing Products (good stuff), he sent three 90deg and one straight, I'd recommend 4 90deg ends, the mounting plate is part of the kit, the filter is a WIX picked up locally (love the black!). I wallered out the mounting holes to square and used chrome bumper bolts to mount it to the fender (clean look) and used rubber washers between the fender and plate.
An line making isn't bad, now I have only a gillizion more to make, used clear duct tape and a dremel to cut the lines flush and 3-1 oil for easy assembly, turned out nice.
The fan is a flex-i-lite 4000 cfm unit. No wiring harness yet, that's later this week. There is about 3" clearance on the fan/motor.
