Quote: I'm not up on what caliper is what but if the A-body one is the same as the R-body then the R-body cop pads etc should work. If the calipers are different but you are using R-body adapters I would think you could then use R-body calipers instead and whatever R-body pad you wanted.
Kevin
The R body and A body Calipers will interchange, some cars got 2.75" piston calipers and others got 2.60" calipers.
