Sounds like you have it to where a more aggressive pad is all you need.
Which is why I was looking at the Police/Taxi listings for St.Regis.
Most parts books don't show an interchange, but that might not be an issue. Wasn't sure if there was a slight change in the caliper and the calipers are only 20 bucks a pop.
The typical parts store pads all tend to fade somewhat once heated up.
Had very good luck with the Wagner Thermoquiet in the past with the turbo cars, we would flog them for dear life. But they might have a different formulation or just the weight difference in vehicles is enough to push them over the edge.
