when the brakes are applied the pistons are pushed out until the pads hit the rotor,distorting the o ring.When released the rubber o ring will go back to it's original shape,pulling the pistons back. If the piston moved 1/32" and contacted the rotor,it will only move back 1/32" to it's original position.
