Quote: yes,1/8 travel seems far too much.perhaps using a spacer position those pistons further out and re assemble?
Spacer??? Maybe your forgetting how a disc brake caliper work If your pistons are retracting 1/8" that's way to far. Like I stated before the seals are pulling the pistons back to far. They should only retract far enough to let the rotor spin without touching.
