Not sure who keeps bumping this up, but here's an update. When I lost the u-joint, it cause more damage than I thought. I got under the car to adjust the clutch and the tie rod ends to make a trip to the Nats. I found this. [
Good that you found it before you hit the road. I had a bellhousing crack in two radially once and the pistol grip about beat me silly before I could get stopped.
Seriously, imagine what would have happened if the trans had dropped down. Yikes.
It was ugly enough when the u-joint went. I thought the car was going to vibrate apart. Also happy it stayed in one piece.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
