Re: Geometry Question
[Re: mcat4321]
#1370143
03/07/15 03:01 AM
03/07/15 03:01 AM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
5.7L HEMI® MDS Operation Both four- and eight-cylinder configurations of MDS have even firing intervals,providing smooth operation. Two cylinders on each bank are active when the engine is in four-cylinder mode – every other cylinder in the firing order. All of the cylinders that are deactivated have unique hydraulic valve lifters that collapse when deactivated to prevent the valves from opening. Engine oil pressure is used to activate and deactivate the valves. Oil is delivered through special oil passages drilled into the cylinder block. Solenoid valves control the flow. When activated, pressurized oil pushes latching pins on each valve lifter, which then becomes a “lost motion” link. Its base follows the camshaft, but its top remains stationary, held in place against the pushrod by light spring pressure but unable to move because of the much higher force of the valve spring. Deactivation occurs during the compression stroke of each cylinder, after air and fuel enter the cylinder. Ignition then occurs, but the combustion products remain trapped in the cylinder under high pressure, because the valves no longer open. No air enters or leaves. During subsequent piston strokes, this high-pressure gas is repeatedly compressed and expanded like an air spring, but fuel is not injected. 2009+ MY 5.7L HEMI® MDS lifters where redesigned to allow for more camshaft lift when deactivated. These newer lifters can be used in prior model year 5.7L engines.
Entire Thread
Gen III Hemi, please post things to avoid and know..
gregsdart
01/15/13 04:58 PM
Re: Gen III Hemi, please post things to avoid,,,,,,,,,
cagebob1
01/15/13 07:32 PM
tboomer
01/16/13 04:10 PM
540challenger
01/16/13 04:45 PM
Guitar Jones
01/16/13 04:46 PM
CHAPPER
01/16/13 05:49 PM
74yellowduster
01/16/13 05:51 PM
gregsdart
01/16/13 06:04 PM
lowflyingdart
01/16/13 06:55 PM
AlexP
01/16/13 06:30 PM
RodStRace
01/16/13 06:40 PM
AlexP
01/16/13 06:43 PM
FastmOp
01/16/13 07:04 PM
MattW
01/16/13 07:05 PM
MattW
01/16/13 07:10 PM
AlexP
01/16/13 11:33 PM
gregsdart
01/17/13 02:11 AM
hemidup
01/17/13 02:38 AM
gregsdart
01/17/13 01:07 PM
gregsdart
01/17/13 12:39 PM
AlexP
01/17/13 05:58 PM
gregsdart
01/20/13 02:39 PM
Kindafast
01/20/13 02:51 PM
hemidup
03/21/13 12:41 AM
hemidup
03/21/13 12:53 AM
Moparmal
03/21/13 01:37 AM
hemidup
03/21/13 05:08 AM
ZIPPY
03/21/13 02:04 PM
gregsdart
03/21/13 12:55 AM
ZIPPY
03/22/13 09:23 PM
Moparmal
03/23/13 01:09 AM
hemidup
03/23/13 02:25 AM
Moparmal
03/23/13 03:32 AM
CHAPPER
03/23/13 01:54 PM
72Swinger
03/23/13 08:22 PM
Moparmal
03/23/13 11:27 PM
Consulier
03/24/13 02:14 AM
ZIPPY
03/25/13 09:39 PM
Cevidicus
03/25/13 11:02 PM
ZIPPY
03/28/13 07:25 PM
Cevidicus
03/28/13 08:30 PM
ZIPPY
03/28/13 08:48 PM
gregsdart
04/04/13 03:56 AM
hemidup
04/06/13 03:50 AM
gregsdart
04/06/13 04:11 AM
LA360
04/24/13 11:51 PM
gregsdart
04/25/13 03:39 AM
hemidup
04/25/13 10:05 AM
gregsdart
08/23/13 03:41 PM
gregsdart
06/22/14 08:27 PM
72Swinger
06/22/14 08:44 PM
gregsdart
06/22/14 09:05 PM
gregsdart
10/26/14 08:34 PM
Moparmal
10/26/14 10:12 PM
Moparmal
11/01/14 09:02 AM
SRT6776
11/03/14 02:34 AM
70blackfish
11/03/14 07:53 AM
Moparmal
11/03/14 03:45 PM
Uhcoog1
11/03/14 08:01 PM
CHAPPER
11/03/14 09:27 PM
72Swinger
11/03/14 09:48 PM
wegner426
11/11/14 04:54 AM
72Swinger
11/11/14 05:07 AM
Intake gaskets
Moparmal
11/12/14 12:16 AM
Re: Intake gaskets
mcat4321
11/12/14 01:05 AM
/6 k mod
roadrunninMark
11/12/14 03:29 AM
Re: /6 k mod
72Swinger
11/12/14 04:54 AM
Re: /6 k mod
hemidup
11/12/14 05:30 AM
Re: /6 k mod
72Swinger
11/12/14 05:36 AM
Re: Intake gaskets
Moparmal
11/12/14 05:54 AM
Re: Intake gaskets
72N96RR
11/22/14 09:39 AM
Re: Intake gaskets
1badx
11/23/14 02:30 PM
Re: Intake gaskets
72N96RR
11/23/14 10:10 PM
Re: Intake gaskets
72Swinger
11/23/14 11:34 PM
Re: Intake gaskets
1badx
11/24/14 07:49 PM
Pistons
Moparmal
11/24/14 11:37 PM
Re: Pistons
Uhcoog1
11/25/14 06:00 AM
Re: Pistons
Moparmal
11/26/14 12:04 AM
Re: Pistons
hudsonhornet7x
11/26/14 05:19 AM
Re: Pistons
gregsdart
11/26/14 08:35 AM
Re: Pistons
AlexP
11/27/14 03:29 AM
Re: Pistons
ntstlgl1970
12/01/14 05:27 AM
Re: Pistons
72Swinger
12/01/14 05:43 AM
Re: Pistons
1badx
11/26/14 08:30 PM
Re: Pistons
onig
11/26/14 10:28 PM
Re: Pistons
Moparmal
12/01/14 10:09 AM
Re: Pistons
ntstlgl1970
12/10/14 09:15 AM
Re: Pistons
MR_P_BODY
12/15/14 03:35 AM
Re: Pistons
Cevidicus
12/15/14 03:43 AM
Re: Pistons
MR_P_BODY
12/15/14 03:51 AM
Re: Pistons
72Swinger
12/15/14 03:54 AM
Re: Pistons
MR_P_BODY
12/15/14 03:59 AM
Re: Pistons
72Swinger
12/15/14 04:00 AM
Re: Pistons
MR_P_BODY
12/15/14 04:05 AM
Re: Pistons
72Swinger
12/15/14 04:13 AM
Re: Pistons
MR_P_BODY
12/15/14 04:21 AM
Re: Pistons
gregsdart
12/15/14 04:40 AM
Re: Pistons
MR_P_BODY
12/15/14 04:48 AM
Re: Pistons
ntstlgl1970
12/15/14 05:15 AM
Re: Pistons
72Swinger
12/15/14 05:21 AM
Re: Pistons
MR_P_BODY
12/15/14 05:26 AM
Re: Pistons
72Swinger
12/15/14 05:29 AM
Re: Pistons
MR_P_BODY
12/15/14 05:33 AM
Re: Pistons
gregsdart
01/29/15 01:46 PM
Re: Pistons
gregsdart
02/16/15 09:16 PM
Re: Pistons
biff426
02/18/15 04:19 PM
RnR heads in car with head studs e body
ntstlgl1970
02/23/15 10:33 AM
Mod Man misery.........
Moparmal
02/26/15 05:37 AM
Main Bearings question
ntstlgl1970
02/28/15 09:12 PM
Re: Main Bearings question
CHAPPER
02/28/15 09:50 PM
ntstlgl1970
03/01/15 02:47 AM
New Eddy dual quad vs old DQ Modman - first notes
Moparmal
03/07/15 08:57 AM
Re: New Eddy dual quad vs old DQ Modman - first notes
72Swinger
03/07/15 09:43 PM
Cevidicus
03/07/15 11:39 PM
WO23Coronet
03/08/15 08:55 PM
Moparmal
03/10/15 03:52 AM
cudaman1969
03/10/15 04:18 PM
Moparmal
03/11/15 10:42 AM
Kevins493
03/11/15 12:40 PM
cudaman1969
03/13/15 04:14 AM
onig
03/13/15 02:20 PM
onig
03/13/15 02:21 PM
cudaman1969
03/13/15 04:24 PM
krw71ragtop
03/17/15 04:51 AM
StricNine
03/17/15 08:46 PM
ntstlgl1970
04/05/15 02:36 AM
Re: Pistons
MattW
12/15/14 04:09 PM
Re: Pistons
WO23Coronet
12/15/14 04:31 PM
Re: Pistons
StricNine
12/15/14 05:13 PM
Re: Pistons
AlexP
12/15/14 05:46 PM
Re: Pistons
MR_P_BODY
12/15/14 06:22 PM
Re: Pistons
sixpackgut
12/16/14 08:20 PM
Re: Pistons
1badx
12/17/14 01:37 AM
Re: Pistons
onig
12/17/14 05:47 AM
Re: Pistons
72Swinger
12/21/14 09:47 PM
Hemi
SRT440DUSTER
12/29/14 09:04 PM
Re: Hemi
mcat4321
12/29/14 10:56 PM
Re: Hemi
SRT440DUSTER
12/29/14 11:29 PM
Re: Hemi
mcat4321
12/30/14 12:36 AM
Re: Hemi
gregsdart
01/07/15 02:40 AM
Re: Hemi
cudaman1969
03/03/15 01:37 AM
Re: Hemi
MattW
03/03/15 01:40 AM
Adrielp
03/04/15 04:33 PM
ntstlgl1970
03/05/15 05:40 AM
cudaman1969
03/06/15 08:52 PM
Copper Dart
03/06/15 09:11 PM
mcat4321
03/06/15 09:39 PM
cudaman1969
03/07/15 01:06 AM
mcat4321
03/07/15 02:12 AM
ntstlgl1970
03/07/15 07:01 AM
Moparmal
03/07/15 08:53 AM
Re: Hemi
cudaman1969
03/05/15 01:01 AM
Re: Pistons
RylisPro
12/15/14 05:02 PM
Re: Pistons
ntstlgl1970
12/15/14 05:24 AM
Re: Pistons
onig
12/15/14 03:38 PM
Re: Pistons
Twostick
12/15/14 07:18 AM
Re: Intake gaskets
cudaman1969
03/08/15 05:38 PM
Re: Intake gaskets
turbofreek
06/02/15 05:24 PM
Moparmal
11/03/14 10:30 PM
hudsonhornet7x
11/03/14 10:57 PM
72Swinger
11/03/14 11:25 PM
Moparmal
11/04/14 12:39 AM
72Swinger
11/04/14 01:06 AM
Moparmal
11/04/14 01:54 AM
GoodysGotaCuda
11/04/14 01:13 AM
Uhcoog1
11/04/14 01:59 AM
72Swinger
11/04/14 06:17 AM
GoodysGotaCuda
11/04/14 02:34 PM
RylisPro
11/04/14 02:52 PM
Uhcoog1
11/04/14 06:03 PM
STEFF
11/04/14 07:11 PM
mr2performance
11/10/14 06:58 PM
72Swinger
11/11/14 04:38 AM
72Swinger
11/04/14 07:05 PM
Moparmal
11/04/14 03:16 PM
Uhcoog1
11/04/14 06:00 PM
Moparmal
11/04/14 11:14 PM
Uhcoog1
11/04/14 01:57 AM
Barry70GTX
11/04/14 04:30 PM
70blackfish
11/04/14 06:03 PM
Moparmal
03/26/13 12:21 AM
John_Kunkel
01/20/13 06:52 PM
gregsdart
01/20/13 07:52 PM
hemidup
01/21/13 09:33 PM
AlexP
01/21/13 09:57 PM
Cevidicus
01/22/13 11:47 PM
hemidup
01/23/13 04:44 AM
Dos Snails
03/18/13 03:09 AM
gregsdart
03/18/13 11:49 AM
BigBlockMopar
03/18/13 12:37 PM
WO23Coronet
03/18/13 02:45 PM
MattW
03/18/13 05:40 PM
Moparmal
03/19/13 10:23 AM
hemidup
03/19/13 03:47 PM
Moparmal
03/19/13 10:10 PM
hemidup
03/19/13 10:33 PM
AlexP
03/19/13 10:40 PM
Moparmal
03/20/13 03:14 AM
AlexP
03/20/13 03:51 AM
Moparmal
03/20/13 05:34 AM
Moparmal
03/20/13 05:37 AM
AlexP
03/20/13 02:29 PM
Moparmal
03/20/13 10:50 PM
hemidup
03/20/13 03:52 PM
Moparmal
03/20/13 10:51 PM
Brian Hafliger
01/20/13 08:20 PM
gregsdart
01/21/13 03:10 AM
72Swinger
01/21/13 07:22 AM
ThermoQuad
01/21/13 12:12 PM
BigBlockMopar
01/21/13 12:35 PM
gregsdart
01/21/13 02:51 PM
SRT6776
01/21/13 02:53 PM
gregsdart
01/21/13 03:12 PM
hemidup
01/24/13 07:17 PM
CHAPPER
01/21/13 02:59 PM
TrWaters
01/23/13 03:11 PM
Quickrunner
01/24/13 03:12 PM
MattW
01/21/13 04:03 PM
BigBlockMopar
01/21/13 04:39 PM
CHAPPER
08/23/13 01:25 AM
Brian Hafliger
08/23/13 02:39 PM
BigBlockMopar
02/05/13 11:01 PM
hemidup
02/05/13 11:45 PM
STEFF
02/06/13 04:16 AM
hemidup
02/06/13 06:42 AM
CHAPPER
02/06/13 05:49 PM
hemidup
02/06/13 07:54 PM
CHAPPER
02/07/13 01:46 PM
MattW
02/10/13 10:06 PM
Moparmal
02/12/13 10:56 AM
hemidup
02/24/13 01:41 AM
Guitar Jones
02/24/13 02:00 AM
Duner
02/26/13 04:25 PM
340RICK
02/24/13 02:33 AM
Moparmal
02/24/13 10:12 AM
MattW
02/24/13 08:26 PM
MattW
02/24/13 08:31 PM
hemidup
02/24/13 10:55 PM
Cevidicus
02/26/13 04:58 AM
hemidup
02/26/13 10:25 PM
MattW
02/27/13 01:47 AM
STEFF
02/27/13 03:03 AM
MattW
02/27/13 02:32 PM
hemidup
02/27/13 10:16 PM
Cevidicus
02/27/13 11:34 PM
wldtm
03/12/13 11:11 PM
AlexP
03/13/13 02:42 PM
Consulier
03/13/13 06:19 PM
wldtm
03/13/13 06:32 PM
72Swinger
03/13/13 08:47 PM
CHAPPER
03/14/13 11:32 PM
72Swinger
03/15/13 12:59 AM
cheapstreetdustr
03/15/13 04:03 AM
72Swinger
03/15/13 04:08 AM
hemidup
03/15/13 04:44 AM
MattW
03/15/13 01:03 PM
gregsdart
03/15/13 01:26 PM
Guitar Jones
03/15/13 01:34 PM
hemidup
03/15/13 01:55 PM
540challenger
03/15/13 02:07 PM
hemidup
03/15/13 02:56 PM
ZIPPY
03/15/13 03:08 PM
hemidup
03/15/13 03:59 PM
72Swinger
03/15/13 09:43 PM
gregsdart
03/16/13 02:20 PM
SC304
03/20/13 03:15 AM
MattW
03/15/13 02:42 PM
MattW
03/19/13 02:01 PM
hemidup
03/19/13 03:53 PM
MattW
03/20/13 12:18 AM
hemidup
03/20/13 01:26 AM
WO23Coronet
03/20/13 01:57 AM
hemidup
03/20/13 02:08 AM
WO23Coronet
03/20/13 02:22 AM
hemidup
03/20/13 04:36 PM
hemidup
02/22/13 06:12 PM
MattW
02/22/13 10:01 PM
gregsdart
02/16/13 04:52 PM
Moparmal
02/20/13 10:58 AM
AlexP
02/22/13 02:46 AM
hemidup
02/24/13 01:17 AM
Guitar Jones
02/24/13 01:26 AM
gregsdart
02/24/13 03:14 PM
We're baaaaack.....more G3 stuff
Moparmal
04/24/13 02:26 PM
Re: Gen III Hemi, please post things to avoid and know..
gregsdart
01/10/15 06:51 PM
ntstlgl1970
01/15/15 09:58 AM
mcat4321
01/15/15 07:49 PM
gregsdart
02/02/15 03:25 PM
gregsdart
02/15/15 04:00 PM
cudaman1969
03/03/15 01:21 AM
72Swinger
04/26/15 05:40 AM
cudaman1969
05/01/15 07:59 PM
gregsdart
05/02/15 03:35 PM
ntstlgl1970
05/03/15 10:01 PM
72Swinger
05/04/15 05:24 AM
sogtx
05/05/15 02:00 AM
sogtx
05/05/15 02:31 AM
mcat4321
05/06/15 03:13 AM
sogtx
05/08/15 02:56 AM
72Swinger
05/05/15 03:43 AM
hudsonhornet7x
05/05/15 04:21 AM
ntstlgl1970
05/05/15 04:49 PM
cudaman1969
05/05/15 04:50 AM
cudaman1969
05/07/15 04:27 AM
cudaman1969
05/14/15 11:40 PM
ntstlgl1970
05/16/15 08:39 PM
Shawndp
07/28/15 02:21 PM
Re: Intake gaskets
superhog88
06/13/15 06:45 PM
Re: Intake gaskets
gregsdart
06/16/15 11:55 AM
Re: Intake gaskets
MR_P_BODY
06/19/15 02:21 PM
Re: Intake gaskets
donscuda
06/19/15 05:59 PM
Re: Intake gaskets
MR_P_BODY
06/19/15 11:20 PM
Re: Intake gaskets
gregsdart
06/22/15 02:32 PM
Re: Intake gaskets
STEFF
06/16/15 06:27 PM
Re: Intake gaskets
LO23
06/19/15 08:12 PM
Re: Intake gaskets
72Swinger
06/20/15 12:00 AM
Re: Intake gaskets
hudsonhornet7x
06/20/15 12:35 AM
Re: Intake gaskets
donscuda
06/20/15 04:43 PM
Re: Intake gaskets
GoodysGotaCuda
06/23/15 12:19 AM
Re: Intake gaskets
MattW
06/23/15 02:06 PM
cudaman1969
06/28/15 04:55 PM
mcat4321
06/28/15 08:32 PM
MattW
06/28/15 08:46 PM
72Swinger
06/28/15 11:48 PM
HotRodDave
06/28/15 11:58 PM
72Swinger
06/29/15 01:40 AM
cudaman1969
06/29/15 02:24 AM
Just-a-dart
07/01/15 01:25 AM
72Swinger
06/29/15 05:53 AM
StricNine
06/29/15 03:51 PM
ntstlgl1970
06/30/15 10:27 PM
cudaman1969
06/30/15 11:34 PM
sixpackgut
07/01/15 09:20 PM
ntstlgl1970
07/01/15 11:57 PM
HotRodDave
06/30/15 11:46 PM
ntstlgl1970
07/01/15 04:11 AM
cudaman1969
07/01/15 06:29 PM
hudsonhornet7x
07/03/15 08:08 PM
mcat4321
07/03/15 10:28 PM
72Swinger
07/03/15 09:34 PM
hudsonhornet7x
07/03/15 10:55 PM
mcat4321
07/03/15 11:06 PM
WO23Coronet
07/15/15 03:51 PM
cudaman1969
07/18/15 12:01 AM
hudsonhornet7x
07/18/15 12:30 AM
cudaman1969
07/18/15 12:42 AM
sixpackgut
07/18/15 06:18 PM
hudsonhornet7x
07/18/15 06:23 PM
ntstlgl1970
07/19/15 10:27 PM
ntstlgl1970
09/05/15 07:35 AM
Chris'sBarracuda
09/27/15 06:37 AM
Just-a-dart
09/27/15 06:48 AM
Chris'sBarracuda
09/28/15 09:53 AM
wegner426
08/10/15 09:43 PM
cudaman1969
08/10/15 10:51 PM
wegner426
08/10/15 11:20 PM
cudaman1969
08/11/15 03:00 AM
wegner426
08/12/15 09:39 PM
cudaman1969
08/13/15 03:25 AM
sixpackgut
07/18/15 06:58 PM
Moparmal
07/27/15 12:08 PM
Street Monkies
09/02/15 08:11 AM
Moparmal
09/28/15 06:24 AM
72Swinger
09/02/15 11:37 PM
Street Monkies
09/03/15 01:42 AM
hudsonhornet7x
10/17/15 03:39 PM
72Swinger
10/17/15 08:05 PM
Wailin D
10/19/15 06:13 AM
Triple Threat
10/27/15 12:57 AM
gregsdart
10/28/15 10:57 AM
Triple Threat
10/28/15 06:33 PM
cudaman1969
10/29/15 10:08 PM
WO23Coronet
10/29/15 10:18 PM
cudaman1969
10/29/15 10:28 PM
Triple Threat
10/29/15 10:15 PM
WO23Coronet
10/29/15 11:43 PM
cudaman1969
10/30/15 04:31 AM
72Swinger
03/18/16 10:25 PM
hudsonhornet7x
03/19/16 03:39 AM
72Swinger
03/19/16 04:18 AM
ntstlgl1970
03/27/16 07:09 PM
RapidusMaximus
09/22/17 06:32 PM
HotRodDave
09/22/17 07:31 PM
RapidusMaximus
09/22/17 07:36 PM
ric3xrt
09/27/17 04:48 PM
A39Coronet
12/24/17 12:55 AM
ta3834bbl
03/16/18 08:37 PM
ric3xrt
03/16/18 08:49 PM
ta3834bbl
03/16/18 08:53 PM
hudsonhornet7x
03/17/18 03:31 AM
AeroMonte
05/12/18 01:41 AM
Greenwood
04/01/19 03:06 AM
Ray408G3Hemi
07/28/19 05:38 PM
Kiddart
07/28/19 09:54 PM
swapdaddyxx1
09/11/19 04:46 PM
biff426
09/11/19 06:54 PM
Moparmal
03/30/20 07:53 AM
HotRodDave
03/30/20 04:40 PM
Moparmal
05/09/20 04:02 AM
Adrielp
08/19/20 03:27 PM
Jeremiah
11/25/20 01:18 PM
moparjim79
11/26/20 01:36 AM
