I am looking at a 06 5.7 out of a Ram.. is this block
a decent starting point.. does it have the VVT.. it
is a complete engine
thanks
Yes, that would work. No, it does not have vvt. Sounds like a good starting point if the price is right. Keep in mind the timing cover and accessory drive are different than on a car. You can't use the 6.1 intake without modifying the timing cover.
Good enough.... also... does the car front end work
on this(timing cover and accessories)
Yep timing covers interchange. But a truck cover might be what you want if you're thinking turbo's since it mounts the alt up top.
Mopar to the bone!!!
