A 545rfe is your best choice. I picked mine up for $400 with 29 k miles. It is controlled by the engine computer so you only have one module the nag uses a variety of sensors all over the car. Hotwireauto.com told me to use the 545 cause it was simpler and cheaper than doing a nag trans a gear vendor od will run about $3000
