Thanks I picked up a complete vvt 5.7 throttle body to pan for 150 bucks with a spun rod bearing. So I have everything from that. Would the pushrods be correct from that engine? Or would it be custom length?
i do not know. i had an early 5.7 with eagles,that took custom PR's.. the 6.1 are different yet. personally i would go with the 6.1 heads, they have better lighter valves
