Quote: a body big block chasis setup, 2 batterys in trunk ,spring relocation kit 12.5mt drag radials, dana 60 rear.now i think you would get more wheelspin with heavier car because ur trying to move more weight.
The lighter the car, the higher in the powerband you would want your torque peak. You would get more wheelspin out of a heavier car when it's springs flex under power. The right gear/tire/chassis combo would cause a heavier car to "hook" well under full power. In your case with the A-body, you also have enough footprint (tire width) as well as tire circumference (in accordance with your present gear ratio) to "hook".
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
