you have no clue what ur talkin about,a good set of j or x heads,a machine shop that knows what its doin and 4" cast crank stroker kit..and u are the one with meth injection on ur BB BEAST? MY little sb pump gas will beat ur meth injected slug by 1/2 the track..THATS WHAT I KNOW ABOUT SB'S...all u say is alot more work!!! but u cant elaborate..u need more work to a stock 440 block cause there boat anchors weight wise
what does any of your posts have to do with what the guy asked??? this is about the 3rd or 4th post where you get on a post to pound on your own chest bragging up your small block. how fast and cheep it is SO WHAT you have a fast small block wohoo
his small block is anything but cheap or small...he has 7 less cubic inches than I do and his car probaly weghs 1000lbs less. His car is super nice and runs like a MoFo, as I've stated anything can be made fast.
Fact is you're not going to make 500HP w/ a small block as easy or as cheap as a 440.
