I agree 5oo hp is 5oo hp. But my opinion is, that if both cars are same hp, at same weight, and properly geared with all the right parts in all the right places, they should be very close the same ET. Because the small block will have a more aggressive cam and wider rpm ramge to make 5oo hp, and also use a steeper converter. But because of the wider torque range, the big block "should" 60 ft better, and the small block "should" mph better, so I think it will equal out. My
Quote: Oh by the way my car can beat your car and I could beat you at arm wrestling and my dad can beat up your dad.
1. I'll race ya! spot me to the 60 ft, my car is heavier with the trans hanging in it, 2. I'll arm wrestle you! spot me 45* and let me use two arms, 3. My Dads car has a WEDGE with a TORQUEFLITE, what's your Dads got?
