Witch one hits the ground first.., from a 1320' drop!
A: 1 pound of lead..
B: 1 pound of feathers..
Has nothing to do with "Big or Small" blocks..
Mike
As long as they are in a vacuum they will hit then ground at the same time..
Now, if you put each into identical containers, then they would also hit at then same time. Even if they didn't weigh they same, everything falls at the same speed. Air resistance makes the difference.
