I'm reading that the fuel pressure regulator will cut out at 45 psi, and that normal operational pressures are around 35 psi. The first shop I took it to said that the fuel pump was good, that the readings were in the normal range for this pump, and refused to replace it. I guess they thought 35 was a good reading, or maybe they were able to get a better reading than I've been able to.
