Update on the transmission project.
Took the truck to mechanic's shop, tuesday before last. Popped in today to find out why I hadn't gotten any news. Found out he'd just moved the truck, with the transmission in the bed, over to his side open lot, and left it sitting in the back the entire time, and through the hurricane. He said "It was covered." I had covered the ends with heavy garbage bags and wrapped a tarp around it.
I pulled the bags off when I drove the truck back home and didn't see any signs of water inside the bags, around the seals, or anywhere near the entrances.
Do I pull the transmission apart to check everything, or do I sound ok? Please advise, I do not want all of my work to be in vain.
