42/44 is the later industry designation that went in to use.
First digit is number if shifts, second number is relative torque capacity, R is rear wheel drives and E is electronic.
As for the slack you are talking about, if it does this first time in the day and does not occur the remainder of the day then it’s likley torque converter drain down.
