Article says Thitek worked production 6.4 heads, specs at the bottom just say Thitek, ported....Either way, very impressive piece for sure! Wonder if it is using adjustable valvetrain with the hydraulic roller.
I'm thinking they use the thitek heads so they can put the best port for the job at hand. Instead of fixing a factory casting. Matt
