There is a phaser eliminator kit from comp cams and one tuner that I spoke with said that its as simple as swapping to an older cam and crank sensor if you wanted to run it on aftermarket efi.
If you go with a factory computer from Hotwire, you can keep the VVT and variable intake manifold.
