So, for the guys that have done this swap... I have a 70 Charger with stock front end/suspension. Is there any factory manifold or srt8 header that will clear the steering box and torsion bar? I'm looking at doing a turbo setup and what sucks about the Hemi, as I'm sure you guys know, is you can't flip the manifolds except with the Thitek heads. I assume I'm looking at a custom header deal, huh?
