Quote: Ok guys David Barton did my lifters. I was at his shop and he took them apart while I was there. There is really not much inside them. He told me sometimes he will put the spring back in the lifter sometimes no. I believe mine have nothing in them No spacers shims etc. I have a few sets of lifters I will try and take some apart and get some pics to share.
Not sure on my compression but cranking compression is 240 PSI
Rick.... you have 240 cranking pressure and you run PUMP GAS... I would never have thought that... I know the timing is a lot less with the gen 3 but damn thats a lot of cranking pressure.... sure opens my mind up on this engine
