Quote: I have only been once. I use to be able to go a lot years ago, but I just don't get to go as much anymore.
I was thinking my problems are just the gear in my car.
I would like to hear the motor combo of the 3700 lb car about to go 9s
430ci, 15:1 compression, Thitek heads, Thitek ported 6.1 intake, 90mm throttle body, PWR designed cam, NAG1 trans, 4000rpm flash converter, 3.06 gear, trans brake, 28" MT ET Streets, custom tuning on our dyno and at the track. Car has run many types of fuel - E85, C16, Q16, C45 - it seems to like the Q16 and C45 the best. The best thing is that this is a 4 door former cop car with a column shift!
