Quote: Take the front right side ladder bar bolt out. If it's a PITA u know your brackets have moved. Set it back on the ground. It should set normal again. I have had this happen on a few rear ends. If you keep running the car it's going to stop going straight as it bends more each launch.
OK. I'll try that. If it doesn't, something is going south?
If you put pre load into the right bar the front bolt wont come out... but if you know the amount of turn (as in a 1/2 turn) then you turn out the pre-load then it should come out... I've fixed multiple cars that they were tearing off the axle housing brackets
