Quote: You SHOULD be able to trust your builder, but I have found that you CAN'T! DC
We're in the same neck of the woods, if there is is someone you feel that I should stear clear of, send me a pm.I've read enough of your posts to value your opinion. Good Mopar builders are hard to find down here, bad ones not so much.
