Quote: have to ask how is the starter mounted when using a chevy bellhousing glide??? and what starter is being used???
Mopar mini starter in stock position and notch the bell or if you don't want to notch the bell use CSR without the nose. others here say they have cut off the Mopar nose and didn't touch the bell with no problems
